REar End Question..pitch or keep
  • Thread starter Thread starter darkness falls
  • Start date Start date Nov 23, 2004
darkness falls
112
Kansas
Nov 23, 2004
  • Nov 23, 2004
I am throuing some of my parts away(don't have many). I have a 67 (stripped and body repair finished) I6 converting to V8. Should I pitch the rear and just look for a entire 9" rear? I want the easiest path. What cars would be best to get the entire rear from? I am doing the V8 conversion because there was no engine as stated previously and really no engine parts period plus everything needs to be replaced anyway. I am basically starting from the ground up, everything will be just about new or used (restored) the only thing I am keeping is the rear glass and the door and quarter windows and mechanics. Everything else will be new.
but I need to know if I should just pitch the 8" rear and find a complete 9"
beanplant
548
KC MO
Nov 23, 2004
  • Nov 23, 2004
That's what I did. It makes it a lot easier. I do believe my 9 inch all came out of a 67 cougar. WELL WORTH IT. I got the housing, differential with 4.11s, and an AOD that runs for $550. Just look for deals!
-Shaun
G
GaPonyFarm
663
Columbus, GA
Nov 23, 2004
  • Nov 23, 2004
Never just pitch anything! You can always sell or trade for something down the road. You might also need the 8" for setting up spring perches on the 9", if its not made for the Mustang.
rbohm
6,698
550
204
tucson,az
Nov 24, 2004
  • Nov 24, 2004
unless you are going to make more than about 400hp(350 with slicks), the 8" rear will do just fine.
Edbert
3,548
32
109
Austin TX
Nov 24, 2004
  • Nov 24, 2004
If I understand correctly you have an I6 now, that means you have a 7.5 not an 8. My advice is don't mess with a 9-inch unless you intend to have fairly serious power and traction (400+fwhp and slicks). An 8-inch will cost less to source than a 9, it weighs less and has less parasitic drag. Perfect even for a warmed up street stang.
If you try to trick out an 8 it will cost almost as much as a 9 similarly treated, but if you are talking about a stock axle assembly for your classic the 8s are CHEAP and plentiful.
darkness falls
112
Kansas
Nov 24, 2004
  • Nov 24, 2004
well I don't care if I get a 8 or 9, the rear I have now is a 4 lug and I need 5 to match the front disk brakes I will be installing. And the 68 Gt rims. I have no use for a 4 lug axle.
darkness falls
112
Kansas
Nov 24, 2004
  • Nov 24, 2004
would the best bet be to go to a mustang salvage yard (live near 4) and get a 5 lug rear from one of the cars there? Or what.
I am going to drop a 428 CJ, it will be a clone car.
beanplant
548
KC MO
Nov 25, 2004
  • Nov 25, 2004
If you're looking for an 8 inch I have one. It's the housing and gears. I'm not sure how good of condition it's in, but it worked well for me before I took it out. I think I actually have an extra set of 5 lug axles too. Just shoot me an email if you're interested. I live in KC.
-Shaun
G
GaPonyFarm
663
Columbus, GA
Nov 26, 2004
  • Nov 26, 2004
If you're going to put that engine it there, you can forget the 8" option. Of course you know you'll be installing a completely new suspension, front and rear.
darkness falls
112
Kansas
Nov 26, 2004
#10
  • Nov 26, 2004
  • #10
Well of course I am going to install a new suspension front an back, Like I stated numerous times, the car had just about nothing on it, all the suspension is completely worn and shot. I have already stripped it to bone fixed all the body work. quarters, wheel wells, engine bay, floor, firewall, trunk, cowl, etc. all done. Just save money right now. REMEMBER this is a ground up restoration. Everying will be new.
But I have limited space and wanted to know what to do about the 7.5, 4 lug rear axle, that I want a 8" or 9" 5 lug.
68rustang
1,537
Cleveland, OH
Nov 26, 2004
#11
  • Nov 26, 2004
  • #11
If you are going to be putting a 428 in the car I would look for a 9".
rbohm
6,698
550
204
tucson,az
Nov 26, 2004
#12
  • Nov 26, 2004
  • #12
i agree with this opinion, go with the 9" rear with a big block.
darkness falls
112
Kansas
Nov 26, 2004
#13
  • Nov 26, 2004
  • #13
which ever is easy to find I guess, this isnt' going to be a drag or street car, just a weekend driver show kind the 428 CJ put out around 335 to 400, depending on who you talk to. But did the 68.5 mustang come with a 9"?
68rustang
1,537
Cleveland, OH
Nov 26, 2004
#14
  • Nov 26, 2004
  • #14
The 8's are going to be easier to find. I have one if you want it. In my opinion you are wasting your time and money with anything other than a 9" behind a big block, show car or not. Based on the HP numbers you tossed out and what the discussed limits of the 8" rear are you would be right up there.
darkness falls
112
Kansas
Nov 26, 2004
#15
  • Nov 26, 2004
  • #15
well then what did ford put in the rear of a car with a 428?
rhyno9
209
Oswego Illinnoying
Nov 28, 2004
#16
  • Nov 28, 2004
  • #16
A 9 inch with a nodular center section. I believe they also came with staggered rear shocks and detroit locker as standard items with the 428.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Tuesday at 7:10 PM
LILCBRA
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
