  • SN95 4.6L Mustang Tech
Rear end question
  • Thread starter Thread starter my_03GT
  • Start date Start date Apr 2, 2006
my_03GT
186
DE
Apr 2, 2006
  • Apr 2, 2006
What's up guys? I am thinking about getting 31 spline moser axels,I would like to run slicks... do I need a 31 spline posi with this set up? Is it benificial, necessary? Could someone explain this to me so I can understand what I need...also is the install pretty straight foward, I have installed everything on my car so far except 3:73's, have alot of tools and like to think I am pretty mechanically inclined, thanks for your help!
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Apr 2, 2006
  • Apr 2, 2006
you'll need the 31 spline differential to match up with the axles. i've never doen the install myself, but i have installed gears and I don't think it would be too hard to do.
my_03GT
186
DE
Apr 2, 2006
  • Apr 2, 2006
Thanks for the reply, thats what I figured..
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 2, 2006
  • Apr 2, 2006
Yes.
if you havent done a gear swap before, take it to a pro
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 3, 2006
  • Apr 3, 2006
it's a little easier to do than a gear swap since you don't have to mess with the pinion or setting pinion depth.
hardest part of this job is shimming the traction-lok clutches.
the98stang
2,408
Clovis, CA
Apr 3, 2006
  • Apr 3, 2006
tomustang said:
Yes.
+1 . Also, you should get a better differential as opposed to the FRPP 8.8 . Possibly a Detroit locker or Eaton. Might as well do it now if you have the cash.
my_03GT
186
DE
Apr 3, 2006
  • Apr 3, 2006
Sounds good, thanks again!
hognutz
1,940
albany, oregon
Apr 3, 2006
  • Apr 3, 2006
read up on the diffs. I got many varring opinions when I did mine.
eatons can break, lockers are noisy
I ended up just getting the 31 spline trac lok.
they make two models. the m-4204-318 and the m-4204-318c. the later having carbon fiber cluthes.
I got the m-4204-318 for $194 from summit the carbon fiber model was $305 or so. you could also get a used on off ebay and rebuild it.
install is a snap really just make sure you get a shim kit and just set the backlash. you will have to remove the tone rings from the old axles if you have abs. the mosers run a bit larger than the ford axels on the machined surface for the tone ring. so I would get the FRPP axels if I were doing it over again. it was a pain to get the tone rings on the mosers. the FRPP models are $25 cheaper as well. they were on back order at the time so I go the moser.
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
