Rear end question?
  • Thread starter Thread starter Dugan
  • Start date Start date Jun 17, 2008
Dugan
47
Portage Mi
Jun 17, 2008
  • Jun 17, 2008
Jacked my 67 mustang up today, put it in drive blocked the passenger rear tire from moving and tried to spin the drivers side and it wouldn't move. Unblocked the tire and they both spun in unison...does this mean I have a locked rear end?
Also what are the ways to tell if I have an 8" or 9" rear end?
Thanks.
ultrastang
1,092
Arkansas
Jun 17, 2008
  • Jun 17, 2008
If the wheels won't turn independently of each other, then it's most likely that you have a Limited-Slip differential, if it's original to the '67. --(Ford Traction-Lok differential didn't come out until 1969).
It's also possible that some previous owner could have installed the differential. If that's the case, then there's no telling what it actually is short of pulling the 3rd member and looking at it.
A quick way to tell if you have an 8- or a 9-inch is to get a 9/16" socket and a 9/16" boxed-end wrench. There are (10) nuts holding the 3rd member to the rear end housing. If the socket will not go onto either of the (2) bottom nuts, it's a 9-inch. (only an open-end wrech will easily go on them). If the socket easily slips on, it's an 8-inch.
Dugan
47
Portage Mi
Jun 17, 2008
  • Jun 17, 2008
PO said it wasn't the original rear end. I will try putting a socket on the bottom two bolts tomorrow.
dodgestang
1,360
Cecil County, MD
Jun 18, 2008
  • Jun 18, 2008
Did the tires spin in the same direction? Then use you have limited slip diff of some sort
Did the tires spin in opposite directions? Then no you do not have a limited slip of any sort
Dugan
47
Portage Mi
Jun 18, 2008
  • Jun 18, 2008
yea they spun in the same direction, i was gonna try to fit a socket on the bottom two today to see if i have a 9" or 8" rear, but was at my brothers all day helping him pull the engine out of his 2000 ford f150.
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
F
Rear Drum Brakes
  • Fri Guy
  • Jan 3, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2025
Scrapla347
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
