I have an 85 gt with the anemic 7.5 rearend. I have located a 89 gt 8.0 rearend. Is it a bolt in replacement, are the lugs compatable? Or should I look for an 86 rearend.
Doesn't seem a bad price to me if it's complete. May want to spend $50 or so for a trac-loc rebuild kit while you're at it. Here's a thread in 5.0 Tech that details the rebuild: http://forums.stangnet.com/showthread.php?t=646823
Head on over to 5.0 Tech and post up. We'd love to have ya stick around!
If you do not want to deal with bleeding the brakes you will have to drain and pull the axles from your stocker. Remove the brake plates and pull them from the housing. Use a wire to hold them up out of the way and then get unget the housing and remove all the hard lines. They are held on by a few retainers and a vent bolt at the hard/soft line connector. Remove all the like parts from the new housing and bolt that bad boy up. I used straight synthetic lube that was reccomended for trac loc\posi rear ends.
86-98 Mustang 8.8 housings and 87-88 Thunderbird Turbocoupe housings are basically the exact same dimensions. If you can find a TC housing, it will have 3.55 or 3.73 gears, a plus if you want gears also. I got my TC housing for $60 without the disc brakes!
The right rear tube has a different breather/brake line set up on the 7.5 to the 8.8. The way it it threads in is different LOOKING, but it is OK. I ran into this on my notch, because it used to be a 4cyl car, but just unthread it, and put the one back in that is hanging from the car. It will work just fine.
