Rear end was causing tranny noises
I just had the gears done and all the bearings and stuff replaced as well and all the noise i heard from my tranny was traveling up the driveshaft and to my transmission. I had a rear end wind as well but its amazing how much quiter it is now the inner rase on the pinon was in bad shape had big gash in it. i believe this is due from oil starvation from a old leak i had along time ago. I will say i recommend when one does gears to replace all the bearings, and 373s is making my car so easy to drive i cant wait to break in the gears so i can really get on it. Tomorrow im going back to put on the output driveshaft speedo gear and tooth. once i would remove my drive shaft and then turn the rear end by hand it would hesistate, wouldn't even turn smoothly, ill have some pics up later once i find my SD card reader
I have this problem myself.
The hack shop I brought it to took forever to guestimate the source of the noise.
They say that my engine and trany are crooked, the drive shaft is possibly bent and they already replaced the pinion bearing.
I have a broken motor mount which could be the reason for the crookedness and all of my rear end bushings are shot.
I want to get it fixed but doing all that sounds expensive and I am saving to buy myself a Kart. It looks like the Stang is taking a break for a year.
Can anyone guess what this may cost to fix at a reputable shop?
Im thinking around a grand...DAMN IT!
