rear gear help.
  • Thread starter Thread starter skunk21
  • Start date Start date Jan 24, 2009
skunk21
1,203
Taxachusetts
Jan 24, 2009
  • Jan 24, 2009
I'm swapping in a T5Z(basically an astroperformance high alloy with z specs) this spring and re-doing the rear end (new seals, bearings, etc). I'm wondering if I should my 3:73's or change to 4:10's while the rear is open. I'm a little nervous that the tall geared T5Z with it's 2.95 1st and it's slightly taller 2nd & 3rd with my mods would make it bogg of the line or not feel like it's pulling right now. The stock T5 I believe has a 3.35 1st and even though 1st doesn't last long it pulls nice. I'm curious about any thoughts on 4.10's being any better with this tranny or stay with the 3:73's.
Brian@PAR
86
Phoenix AZ
Jan 25, 2009
  • Jan 25, 2009
You will see a difference and the 4.10's will make that up almost completely. With that said 3.73 with a 2.95 first is not a bad ratio for a street car.
I've run 3.55's with a 2.95 1st and not felt as the car is bogging.
skunk21
1,203
Taxachusetts
Jan 26, 2009
  • Jan 26, 2009
Maybe I'll keep the 3:73's then since 90% of time the car is street driven. I was just curious, talking with some other people they said going to a taller first takes away from the 3:73's a little compared to what I'm used to now with my current setup/mods.They brought up the 4:10's like you stated to make up the differance and it got me thinking. Thanks for the help.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jan 26, 2009
  • Jan 26, 2009
stock T-5's have a 2.95 first gear TKO's have a 3.27 first. i would stick with the 3.73's unless you are planning to use a 28'' tire in the rear. I have 3.73's with a 275/60(28'') tire and it is great out of the hole and the highway cruise is 2500 rpms at 75mph and 3000rpm at 80mph.
3.73's are an awesome all around gear IMO
Brian@PAR
86
Phoenix AZ
Jan 27, 2009
  • Jan 27, 2009
just as a point of clarification. Stock T5's don't come with a 2.95 first. They have a variety of ratios depending on the application but only the aftermarket T5's (T5Z) has the 2.95 first
Modern Driveline - T5 Transmission Specs
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
