rear gears for a t56
Contrary to popular belief having a 6th speed doesn't effect your highway cruise RPMs. My buddy just went through all this and found that 6th gear is almost the exact same gear ratio as a T5, and 1st through 4th are almost the same too...they basically just added a gear between 4th and 5th to add a 6th gear. You should be fine with whatever you gear you would normally run...probably a 3.73 or 4.10.
Yup, 6th gear on the Cobra T-56 is actually the same gear as the same year GT.
So in my GT with 3.27's, my cruisng RPM in 5th is actually slightly lower than my friend's cruising RPM in 6th gear with 3.55's in his Cobra.
However, there are T-56's with low 6th gears. I beleive the Viper has a 0.57 6th ratio.
The Cobra t-56 is 0.63 in 6th. The t-5 is 0.67, so not much of a difference.
You just basically add the extra gear BETWEEN 4th and 5th.
Also, the first 2 gears are a little taller, so you can actually make your car slower if you dont have the power to overcome it
Don't go too high with the rear gears. The 6-speed has more gears, closer together, and if your rear end ratio is too high, you'll have to shift through them very quickly.
So pick a gear that'll get you up into the power band relatively quickly -- maybe 3.55s. :shrug: The closer gear ratios will keep you higher up in the power band each time you shift. That's where the advantage is.
There are aftermarket 5th gears for the T-5 that are a lower ratio for highway cruising in 5th gear.
Of course, i've been wanting to do a T-56 swap myself...just for the sake of a MUCH stronger transmission and just to say i have 6 gears :)
Like said before, there are different versions of the T-56 with different gear ratios. You gotta put a little thought into which will work best for the HP your engine is putting out
Another thing i didn't like was how close the gears were. That might sound stupid since most people want that, but i was constantly going into the wrong gear. There's very little left to right movement needed at all to change gears. I guess that's good for some people but i hated it. For the price i'd just got a TKO 600.
