rear gears
gregsmy
30
I am thinking of changing the rearend gears from 3.27 to 3.73 and had a couple of questions. First what type of performance gain would I likely see and is it worth it? Second, are all the 8.8 gears the same? I found someone locally that has a set from an Explorer rearend and I want to make sure they will work. He also has a limited slip carrier as well for 31 spline axles. My vehicle is a 36 Ford truck with the drivetrain from an 87 Lincoln LSC
