  • SN95 4.6L Mustang Tech
Rear howl, slipping rear end? Stock gears.
  • Thread starter Thread starter supergoat
  • Start date Start date Feb 10, 2007
1 of 2 Next Last
supergoat
34
  • Feb 10, 2007
Car has 19k miles on it.
Sometimes when I punch it in 2nd or so, the car will pull very nice like it's supposed to. But other times it will just kind of go, feels like the clutch is slipping, but it's not. The clutch grabs extremely well. But all the power is not there. It's pulls forward a bit then you can slowly feel/hear the power come on like it's "catching up".
And last night I noticed a howling coming from my rear and a little noise at low speed turns. The gears are factory stock.
It's still under warranty, but I'm 3.5hrs away from home, it's the weekend AND there are no Ford dealers by me anyway, and want to make sure it will make it home, This all started after I was already here, otherwise I would not have taken it on the trip. . Any idea what it could be? I do have the t-lok rear.
sgarlic
3,085
Feb 10, 2007
  • Feb 10, 2007
Just drive it home. If something fails on the way, and it's Ford's own fault, they pay for the tow truck, and any associated repairs after it gets there.
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Feb 10, 2007
  • Feb 10, 2007
Well rear ends cannot slip. They are physically meshed gears so no slippage can occur.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Feb 10, 2007
  • Feb 10, 2007
if i recall, the only thing in the rear end that could slip would be the clutch packs in the trac-loc, but that would only make you one-wheel-peel.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 10, 2007
  • Feb 10, 2007
the differental pinion gears or side gears as many call them can slip and grind away I have seen some where the teeth were worn or ground right off of them. It's possible that this happend and the metal bits ruined the bearings causing the howling you are now hearing.
I would think you would have noticed more than just a bit of power loss if this happend
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 11, 2007
  • Feb 11, 2007
The Trak-Lok rear ends have clutches much like the clutch for the transmission. The Trak-Lok rear can absolutely slip when the clutches are worn.
There is also a S-Spring(differential clutch spring) that preloads the clutches and holds them up against the side gears. This spring can wear and become weak allowing the clutches to slip. There is an upgraded heavy duty s-spring made by Ford.
Ford Part# F3TZ4214A
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Feb 11, 2007
  • Feb 11, 2007
But that sort of slippage would only occur when one of the rear wheels spin. It would result in a one-wheel peel because the clutches would not transfer power to the other wheel.
In a normal state, with both wheels gripping the pavement and not slipping, it would be inpossible for the rear end to slip because the clutches would not be being used in that situation.
supergoat
34
  • Feb 11, 2007
Thanks for the replies guys. It made it home just fine. Going to the dealer tomorrow. The howl actually got quieter as I made it close to home so we'll see what they say.
R
Red2000GT
2,450
Regina,Sask.Canada
Feb 11, 2007
  • Feb 11, 2007
Let us know what it was,my guess is a bearing packed it in and may have caused the trac-lok to slip. You'll lose a little "acceleration power" as the one tire breaks loose then grabs again as the lok kicks back in.
supergoat
34
#10
  • Feb 11, 2007
  • #10
Well if anything IS indeed wrong in the rear end and they have to take it apart. I'll get them to install a set FRPP gears for me since the labor would be covered by warranty anyway.
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Feb 11, 2007
#11
  • Feb 11, 2007
  • #11
I honestly think the problem is elsewhere and not in the rear end
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 11, 2007
#12
  • Feb 11, 2007
  • #12
The rear end can slip just as if the transmission clutch were slipping. It's not mechanically locked at all. Trust me I've driven a bunch and rebuilt even more. The only way to mechanically lock the axles to the carrier case is with a locker or spool.
There are splined steel discs that are stacked with the non-splined friction discs on the side gears. The differential case itself does not transfer power to the axles, the clutches transfer power to the axles by way of the side gears. If the friction discs get worn, the rear end can slip and it will feel just like the manual transmission clutch is going out.
This guy should first make sure his clutch isn't slipping and make sure it is adjusted properly, then look to the rear end.
blkhorse
345
Feb 11, 2007
#13
  • Feb 11, 2007
  • #13
the axles are mechanically linked to the carrier thru the pinion gears and cross shaft,you may have rebuilt a lot,but you don't understand the operation
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 11, 2007
#14
  • Feb 11, 2007
  • #14
I'm sorry but you are wrong. The primary means of friction between the splines on the axles and the splines on the inner side of the side gears are the splined steel discs. If you were to leave the splined steel discs out or leave the s-spring out your rear end would quickly be destroyed from the free spinning carrier case. That's just the way they work.
blkhorse
345
Feb 11, 2007
#15
  • Feb 11, 2007
  • #15
if you took out the parts you mentioned the rear would destroy itself from the pinion gears and side gear clearance,the posi rear axle is nothing more than an open diff with a preload on the side gears to aid in traction.I have also rebuilt many rear axles over the years,might want to rethink your view on the operation of a rear axle
Mike97gt
it doe snot
10,633
Feb 11, 2007
#16
  • Feb 11, 2007
  • #16
As I said a few posts earlier in this topic the power is transfered through the differential pinion gears the top and bottom gears have a hole that the cross shaft goes through and the side gears are splined to the axles and friction dics plates.
IF the pinion gears are damaged then you can have slippage and this will continue untill the gears are destroyed and the car will not move.
It is somewhat common on 8.8's to damage the diff pinion gears, I have had to rebuild several of them that this has happend too..
In this case i don't think thats the problem because if those gears were damaged then they would rapidly destroy themselfs to the point that the car will not move.
blkhorse
345
Feb 11, 2007
#17
  • Feb 11, 2007
  • #17
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 11, 2007
#18
  • Feb 11, 2007
  • #18
Most of the time the side gears and/or the carrier pinion gears will get damaged when the friction or steel discs get worn or damaged, but the rear end will not always just grenade. Sometimes they will hold on for a while. And like I said, it can feel just like a M/T clutch slipping. The pinion shaft doesn't just hold the pinion gears in place, the pinion gears actually rotate on the pinion shaft.
With that being said, these 8.8's don;t usually give up the pinion gears or side gears, it's usually a disc or axle problem, and if he has a rear-end problem that is likely the source.
blkhorse
345
Feb 11, 2007
#19
  • Feb 11, 2007
  • #19
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Feb 11, 2007
#20
  • Feb 11, 2007
  • #20
blkhorse said:
I know, it's hard to grasp reality.
1 of 2 Next Last
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Rear end catch can? Anyone? Bueller?
  • DadLife0724
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2025
90trunk
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
