Putnam don't post anymore please.
Yes you can do it. If your some what mechanicly inclined you should do fine. You'll need to drop the mid pipe out, then take out the drive shaft, then the tranny, then bellhousing, then clutch and flywheel. You'll be at the back of the block now, the rear main seal will be right there. Should be about to carefully pry it out with a screw driver. Then the new one should go in pretty easy, just make sure its nice and flat. After that just put it all back together! Honestly if its not leaking insanely bad just leave it, 302's generally always leak.
