If you want a leak free one, order the Felpro one piece gasket made for the early mustangs. It's around $50 but well worth it IMO. It is a rubber composite with a steel core and leak free performance. Reusable too and no RTV required!
Also, the type or rear main doesn't affect the pan gasket. BUT, the year of pan does. The early pans had ribbing in the pan flange to prevent the cork from squeezing out. The later 5.0/5.8 engines had flat flanges, thus the gaskets are different. Felpro makes a specific gasket for the early pans (early i mean pre 5.0) and is available at autozone. I know you aren't running a 5.0 pan (cause it is rear sump) but they may try to give you a 5.8 pan gasket.
