#@%&!* REAR MAIN SEAL
ss93cobra
1,422
Wilmington NC
Hey everyone. here's one for you. Stock 88 block, Ford Racing stock spec. crankshaft, main caps, etc. The rear seal starts to leak after @ 15 minutes of idling. Motor was just put back together as well. Oil pressure of 60 at an idle, 80 at 2,000 rpm. Yeah, a little high but I doubt its the culprit here. Running a breather, no blowby, using a pcv and that's it. After it gets good and hot, the rear seal starts to leak. Both seals used were from Ford Racing and Ford and both leaked after @ 15 minutes of running. Seems to be coming from the exterior edge of the seal, not seal to crank. Nice steady drip. Seal installer was used as well. Even squirted some silicone on the edges when the second one was installed. Block was inspected for a nick or scratch as well. It's :bang: :bang: Any thoughts? Anybody have a part # for a seal with a slightly larger o.d. ?
:hail2: Thanks! Keep your fingers crossed. BTW, I forgot to mention it's a 306 with a Vortech 12-14lb pulley on her with Roush 200 heads and an Anderson cam. It shouldn't matter though since it's never seen boost yet, all was at idle or slightly above idle.
You probably already know this ... but put the silicone on the block/seal and then let it sit overnight before starting to ensure a good seal. Rick91gt is the guru of this stuff ... thanks to him my rear main no longer leaks :nice:
I hear you, I really do..245 miles on the mill..just a baby, and what do I find on the tranny back plate..a drop of oil..where from...the rear main, yup a leak. I have chosen to ride it out untill winter when I pull the tranny for a rebuild..however my car only sees about 2-3 hundred miles a month. Good luck no matter what you decide to do.
