Rear Seat delete with sub box?
Blev
1,295
So. Cal. V-Town
I saw a thread a long time ago where someone did the rear seat delete and installed a sub where the bottom seat once was. I did a few differant searches and can't find it. Does anyone have it saved or know the specs on the design. I'm going to be fabricating one myself but would rather not reinvent the wheel if the specs are available.
I used a 1x4 to raise up the top of the box a bit from where it would be if I just had put down the plywood. It is easily removable at the track as well
Your the one that I got the idea from!!!! Thanks for the reply. Did you design the entire kit yourself, or did you modify one? Do you have the specs?
I did the whole kit myself. I would suggest you get a few big boxes and cut those out to make some templates to get what you want. make a complete mock up out of cardboard and then cut the wood from that. I should get a couple of pictures of the underside of the delete. The nice thing about it is that I can remove it in under 5 minutes. It isn't even bolted down!
