rear seat removal..
weaver81
Hey guys, I'm in the process of removing the MACH 460 in my 02 GT and needed to get some room to work and route wires. Is there a trick to getting the rear seat out or does it just pop up? Thanks.
it's 20 seconds :)
feel under the front lip of each bucket - right in the center of each side of the seat you'll feel a hard piece of plastic - those are your two latches.
Using flat blade screwdriver, push on the front of the latch (push gently towards the rear of the vehicle - it only pushes about 1/8-1/4 inch. pop up that side of the seat and repeat for the other side...
Once the 2 latches are released, just lift the seat up from the front and then pull it out to remove it.
Here's a picture.
