Rear Shackle Placement
Denver83
22
So in examining my gas tank problem I noticed a problem with my rear shackles. They are the super long shackles (6-8 inches), but it seems like the longer shackles are putting too much twist on the mounts. I have ordered new, shorter shackles, I just want to make sure they are safe and secure when I install them. The first pic is driver side, the second passenger side. My questions are, does the shackle mount to the frame rail, and what is the best way to fix the problem?
I just had to partial rail replacement on my 68 coupe and found a hole bunch of rot in other panels. IMHO, you should take a close look at your sheet metal (Qtrs, wheel wells, trunk brace, trunk drop offs etc.) and replace all bad panels at the same time. Also suggest you use the Eastwood Internal Frame Coating paint to help stave off further rust issues. Just my thoughts.
Reactions: 7991LXnSHO
I know the left side of the trunk beside the fuel tank has some small holes, so I know that needs to be replaced. I've been considering taking the car down to get media blasted, but right now I have more time and energy than money.
What are the other options for rear suspension? I was watching a youtube video where Stacey David on Gearz replaced a suspension with a heavily braced rear that didn't connect to the shackle mount. It made me wonder what else is out there.
