you could try 5.0resto.com They have alot of stuff for our cars but I don't like dealing with them over the phone so the web site would be your best bet.
When I did my 5 lug cobra conversion, I got my stainless rear lines that run from the hard lines to the calipers from www.classictube.com.
They will ask what type of application you are using them on and make them for you. When I ordered mine, I did not want to use adapters to fit the 94+ rear calipers to my hardlines, so they made one end to fit the caliper and one end to fit my existing hardlines. They are great quality.
Good price as well, $70 bucks for the pair, custom made for your application.
Ok, I'm going to clear up some confusion. So you need the hard lines that run on the axle housing? Ok the easiest way to get those is to just take the car to a brake shop and they can make a set for you for about 20$. Stainless Steel lines are the stronger flexible lines that run between the hard lines and the calipers.
Calipers! I thought he said he had drums. I would check the local shops in your area. I take it you are having a problem with the hard lines getting bent or pinched by the axle tubes?
