Blue Thunder
HaveII said:Is this setup welded to the axle housing or does it bolt on? Would those springs be too heavy?
Blue Thunder:
Any idea when you plan to start working on this? I sure would like to follow the project when you do.
Also: Any idea what a junk yard might charge for something like that?
It would require welding brackets to the housing.
The springs would most certainly be too stiff for the II. Those SUVs weigh probably 4100-4400 pounds. The back end of the thing weighs almost as much as the entire II. But PST in new jersey, or any similarly-equipped suspension shop can make custom springs for any application. (You'd just tell them what you did, and how much the car weighs, and they'd guestimate the spring weight requirement)
I have a HELLUVA lot of things planned for my Stang this year. The ladder bar suspension swap will be close to last on the list, so if I do get to it this year, it will be middle to end of summer. But I will add pics and document every step on my website. (worldofwargod.com)
