Rear suspension Q's
So do I want the rear end to stay flat in corners or articulate through full range of motion in turns. I was reading Late Model Mustang Suspension Basics and it says "If you use your car in open track or autocross competition, you'll probably want to leave the stock upper control arms alone and install only new lower control arms. The stock rubber bushings in the upper arms continue to allow the axle to articulate through its full range of motion in turns, while the new lower arms improve axle location."
http://www.miracerros.com/mustang/t_suspension.htm#Rear
But if I get new sway bars from say Eibach, or Addco etc. I will be fighting this to keep the car flat. Now Im really confused. Ive done springs, shocks/struts, camber+caster plates, rear lower control arms and SFC's. Im contimplaiting sway bars, but not sure if I want/need them. :shrug:
see the whole point of the UCA's is that they're trying to do 2 jobs at once locate the side to side movement and axle windup, now the stock bushings suck so it's good to upgrade to a better UCA with rubber bushings, it'll allow better movement of the axle without too much binding. When it comes down to it you can let them go and decide on another suspension part to put in, you can hold out on UCA's.
And if you want to be hardcore about it you can opt for a Torque Arm system (replaces the UCA's) but that'll also include a panhard bar setup and maybe a fully adjustable swaybar
If you want to stay flatter in the corners get a panhard bar, if you can try to get a stiffer rear spring too
You don't need a new front one, it's big enough. You can upgrade the bushings on them and have better end links. A rear adjustable sway bar can be fine tuned for understeer/oversteer
I'm guessing you have a stock rear bar on? If you so the stock cobra replacement is a step up on stiffness and strength over the stock GT one, you can feel the difference, the side to side movement does disapate just a little with one
