Rear Sway Bar!!??
Ny Mustang Guy
322
Queens Nyc
Help.. Rear Sway Bar!!??...
Just wondering if it would be good to put a rear sway bar on?.. When I bought the car I didn't notice at first but it doesnt have a rear sway bar. Will i see a significant difference in handling with the rear swaybar? if so aftermarket or stock replacement?
My car is a DD, Front suspension: 4 Cyli springs, KYB Gr2 Struts, NO Front SwayBar (Swaybar Bushing Broke so i took it off) 15x3 1/2 Welds w/165r15's
Rear Suspension: GT Springs, Lakewood 50/50's, MAX Motorsport Adj. LCA's, Stock UCA's 15x8 Welds 295/50/15's
I dont speed or shoot around corners quick, so the notorious swaying from making sharp turns doesnt bother me @ all... sometimes if I may cut a turn a little sharp my rear tire(s) may scrape slightly, Nothing too bad to eat up the tires but they do scrape once in a while.. more with a passenger(s), Sometimes even going slow making a turn up a steep hill. Just curious... If I get a rear sway bar and slap it on will this help a little with the slight rubbing on corners? or is it better to just keep it as is?
Another question is do you guys think the KYB GR2's will hurt my car much in the 1/4? I bought the GR2's bc it is Daily Driven.. would it be better to get Lakewood 70/30's, or 90/10's? are the GR2's stock replacements? Will the swaybar help or hurt my 1/4 times?
Sorry for all the questions!
Thanks:flag::SNSign:
My $0.02
The rear sway bar helps control some amount of body roll when you are cornering. Not as much as the front swaybar though. As a street driven machine I would use one. However, I prefer to go fast around corners and not fast in the 1/4 mile. Your car will have better weight transfer without the bars in place on the track. Your setup seems to be more for dragracing than driving...
I can't answer your shock question. I have stock repots on my car.
thanks for the info, I was curious because the main reason as to why i asked the sway bar question is because i was wondering if putting a rear sway bar will help in not allowing my rear tires to scrape up against the fenders when making a sharp turn. the scraping isnt that bad but if putting the rear sway bar on will help a little I will do that..
Probably will help, without the sway bars that car is likely a body roll machine. Allowing your suspension travel to be too far for opposite corners.
Do your self a favor, and try putting them both on, on the street they don't affect performance much if any at all, since traction is likely not enough for a dead hook.
I wouldn't use kyb anything, even if you gave me them for free.
You can try koni reds for shocks, i'm told the softest rate inside of them is 70/30. (i do not know this to be fact yet)
And i know from experience with using them with a drag suspension, you don't hurt a thing.
I ditched the drag setup after 2 weeks, because it gave me a very unsafe feeling.
I would add a rear swaybar. Get one from an junkyard Mustang, Tbird or Cougar. I just put one from a Cougar onto my 89 LX four cylinder and it made the ride and cornering smoother and steadier. I kept the rear on the 82, even with the traction bars and air bag. They seem to help drag cars.
I have not missed the front one on the 82 at all, but I am not much on going fast around corners.
thanks for the info everyone, I'll be getting that rear sway bar soon. :nice:
:SNSign:
