Anyone have these shock with this problem? I have had them for about a year. They now sqeak if I push my car up and down in the rear. Does Tokico have a good warranty? This is very annoying and I would like to try anything to fix. pleae HELP!
Do you have zerk fittings in your control arms? Do you even have after market rear control arms? If you do, most of the time, those will squeak. Check it out.
Take the top mount off and put a little grease on the bushing or wherever you suspect it to be coming from. You could try spraying WD-40 on it too. Use common sense and find the source of it. Have someone bounce the car while you locate it.
Edit: Dont be under it while they are bouncing it!
