Rear vibrations
bbbngowc
32
Hey guys,
Just wanted to get some input to what could cause vibrations coming from the rear of the car when traveling at 60+. Cruising under 60 the car runs fine, but once I accelerate past 60, I start feeling some vibrations in the rear.
Do you think the rear wheels need balancing? The HB is new (replaced back in Jan 08). What else could cause this?
Oh ... It's a 1991 GT. No special mods. 17x9 Cobra R's wrapped in 255/45 Tires.
Could be a variety of things from the rear end not having the dogbone, to a tire out of balance, to a driveshaft out of balance, a bad tire, to the rear not being spec'd/shimmed up properly.
Well it wasn't always doing this. I can't say when it started exactly as it's not my dd. This is only the 4th time for the year I took the car out.
Where should I start to troubleshoot this? I'll have the rear wheels checked for balancing and go from there. Anything else I should be looking at? You mentioned the dogbone. Am I checking to see if it's bent, broken or missing?
Personally-I would go the cheapest route first. Take the rear tires off and inspect them for bulges on the sidewalls as this sometimes causes that wobble you mention-when it happens, If it happens.
Then while tires are off car, Check to see if dogbone is on car.
Then go for the $$ part, get the rear tires high speed balanced and take it from there. Im guessing, One of your wieghts popped off the rim, maybe while you were clenaing it or somehting, hit a pothole and caused the wheels to cause the vibration.
"dOGBONE" dampens vibration in the rearend. Antoher one of FORDS bandaids ahhahah instead of fully engineering a real fix to the rear, driveshaft etc... Its located on the bottom of the rear end.
I wondered what the hell that was mounted on the rear end dogbone you called it . I had a 93 LX about 12 years ago and that car did not have one. I have a 90 LX now and it does. Did ford fix the problem before 93?
All foxbodies have them. they dampen vibrations. Some poeple take them off to save about 5--8lbs if that, and then they find down the road-they start having noises and vibrations. personally-I leave them alone. If FORD put it there, It was for a reason, Trust me, they dont spend $$$ on things for fun or looks, There is always somehting wrong that needed it. hahahaha FORD is cheap!!!! For them to spring for the loot, its needed to save on a real fix, Ya dig? :nice:
