  • 1994 - 1995 Specific Tech
rear wheel play
  • Thread starter Thread starter chefster
  • Start date Start date Apr 7, 2005
chefster
426
michigan
Apr 7, 2005
  • Apr 7, 2005
when rotating tires the other day i noticed one rear wheel had some loose play in and outand some leakage,whats the game plan?
95CobraMike
1,046
Lima OH
Apr 7, 2005
  • Apr 7, 2005
how does your car drive?
where was the leakage from?
RIO5.0
6,892
N.H.
Apr 7, 2005
  • Apr 7, 2005
Sounds like axle bearings and seal...Not alot to fix....fairly cheap actually...
in and out I would expect some play...grabbing the tire and side to side would no be good...that would be the bearing or I would suspect that..
chefster
426
michigan
Apr 8, 2005
  • Apr 8, 2005
the car drives great ,I notice when going around a turn the brake pad whistles alittle on the rotor. The leak is from the bearing seal..do i need to pull the axle to replace it?
RIO5.0
6,892
N.H.
Apr 8, 2005
  • Apr 8, 2005
Yup..Axle has to come out...Its not that bad..just gotta pull the dif cover as you have to remove the C-Clips to get the axles out....that means the dreaded ABS sensors have to be removed...cant get the axles in far enuf to pull the C clips with them in place....Those can be the worst part if the stuck... If they come out easy, you got it made....
Do you have a seal puller??? kinda looks like a pick axe??? if not get one...they're cheap and work sweet...
chefster
426
michigan
Apr 8, 2005
  • Apr 8, 2005
ok ,sounds good,soon as i kick this virus,i'll tend to it.thankss
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
