Rear wheels bind up
Whitehorse88
24
Back story is I just purchased an 88 coupe. I in the middle of going through the car and see what’s been done to it and also neglected. I was checking the rear end. I had the car in neutral with e brake off. Started rotating the tires. Got about 3/4 the way through a full rotation when it suddenly stopped. Checked for drive shaft catching on something, it wasn’t. During my shake down run with the car, I felt clunking at low speeds when making a left turn. But it doesn’t do every time. My thinking is something with the rear diff or axles. Does anyone have any insight before I blow this rear end apart?
Ok. I’m stupid. When I had the rear of the car on jack stands, I didn’t raise my pinion angle to normal ride height. My bad. That fixed the binding but I still have this rapid clunking, for lack of a better term. I was able to duplicate, somewhat, while the car was on stands in first gear. When it was on the road, it would only do it when I turn left and it was much more noticeable. And it’s not all left turns. I also noticed a squeak when the tires were rotating at a decent rpm. I’ve checked for slack in the drive shaft....nothing. Not sure if the 2 are related. Any suggestions outside of rebuilding the rear? This is where I think my issue is
If this is a V8 car it will have a traction lock type differential, if it has a lot of miles on it pop the rear cover off draining and clean the inside with brake cleaner then use black rtv and install the cover, add gear oil with some friction modifier the find a parking lot and do slow figure 8's, about 6 or 8 should work, that may take care of the noise. While your under there check your control arm bushings for damage or ware.
