Rear Window Removal to Get at Ornament Screws - 1966
pekoe1111
76
Are the two top bolts described below the ones accessible through the 1.5" holes in the inner quarter?
>>>>>>>Remove the 2 bolts at the top of the rear glass run (one on each side). Remove the 2 bolts at the bottom of the run (one at each end of the L bracket). Now with the window rolled, down, pull the glass + track up and out of the way. It will not come completely out this way, but will give you PLENTY of room to easily remove the 1/4 panel ornament.
Installation is just the opposite. Should take about 1/2 hour per side to remove or replace.
