- Feb 27, 2007
- 144
- 0
- 0
I have a 1969 351w and was planning to do a master rebuilt, but was wondering if a 393( just adding 302 pistons and a differnt crank) would be "better" than a master rebuild?
. Thats why I'm debating on either getting a master rebuild or build the 393(302 pistons and different crank.)The only time a 393 was "cheap" was when there were no aftermarket cranks, rods and pistons. Soo many guys run into this very problem you will have. It will cost 200-400 to balance the "cheap" 393 when using an aftermarket crank, stock rod and 302ch piston. Then 99% opf the time the piston skirt has a good chance of hitting the crank counterweights. You are money ahead doing a 408, they balance with no heavy metal needed and bolt together, the old "cheap" 393 days are gone. Do a rebuild on your 351 and call it good.
Couple things, first I own those linksactually the 408 was the earliest stroker crank for a 351w engine. it still needed a lot of work cutting down the counterweights, and a custom piston. the 393 is a custom crank, and if oyu follow the links that ratio and i put up you will find the cranks, ready to go, are $270 plus shipping. and since you reuse the stock 351w rod, and off the shelf 302 pistons, you can build a nice stroker for the street that makes good power, and if you can assemble the engine yourself for less than the cost of a stroker kit rotating assembly.
secondly, the 393 is one of the earliest strokers before any aftermarket. Take a stock 3.50 windsor crank, offset ground to 3.850, use a 5.956 windsor rod with a 302 piston, this is 15 years ago bud. Again the problem with the majority of 393's is they take 3-5 slugs of mallory metal to balance to 28 which is anywhere from 200-400+ dollars just for balance, then most guys trying to build a 393 on the cheap buy the cheapest 302 pistons and the skirts are too long thus necessitating you mill the piston skirt, been there done that in the 90's. The 408 is a youngin'
Some guys never learnI think I'm just going to build the 393 (crank and pistons ) because I'm only trying to make really good street power.
- So I already know I'm going to buy a SCAT 393 crank. What kind of 302 pistons would you guys recommend? And, do I just use my stock rods?
Couple things, first I own those linkssecondly, the 393 is one of the earliest strokers before any aftermarket. Take a stock 3.50 windsor crank, offset ground to 3.850, use a 5.956 windsor rod with a 302 piston, this is 15 years ago bud. Again the problem with the majority of 393's is they take 3-5 slugs of mallory metal to balance to 28 which is anywhere from 200-400+ dollars just for balance, then most guys trying to build a 393 on the cheap buy the cheapest 302 pistons and the skirts are too long thus necessitating you mill the piston skirt, been there done that in the 90's. The 408 is a youngin'
The link is MY store bud, they are not even close to neutral balanceYou don't make sense...![]()
We are not talking about offset ground cranks and mallory metal here.
The cranks in the link are custom cast and very close to neutral on balancing.
They are not made from stock cranks like you hint.
I will leave it to the know it all's now.The link is MY store bud, they are not even close to neutral balanceI will leave it to the know it all's now.
