basically rebuilt stock 99 motor, new crank, everything stock besides heads just got valve job and polish.
anyway got it in everything is hooked up correctly as it was all labeled. fired up and right bank is not firing.
good compression, good spark, fuel injectors working. even swapped some around to the other side to be sure.
engine does idle but there is no difference when you unplug any injectector or plug wire on the right side, however there is a very noticeable difference when you unplug anything on the left side.
right side header is cool in comparison to the left.
wtf?
wtf?
