I have asked this before, but just need a clear answer and recommendation. Ofcourse the goal is to make more power and try not to waste money on items that are not needed. So where ever i can save will be appreciated.
Goal is to make approx 300-320RWHP, not spend more than $3K from start to finish. I have PI heads on my car right now. What i was thinking was rebuilding the block, not sure how thats done, but i have heard if you change pistons and better valves and such it will net some power. ALso was thinking about cams, which will you recommend? The car is a daily driver, currently has approx 150K miles.
This is what i was looking at...
http://www.modularmustangracing.com/...hortblocks.htm
Will i need anything else if i get that? do i resuse the heads on my car, along with getting a better cam?
Another question, is it worth getting the heads port and polish to stage 3? they are claiming an additional 35HP, costs $750,is that accurate
, so its lighter and stronger then the GT blocks....
. i also found a 5.1 forged stroker kit for about 1500 if i can remeber right
