rebuilding a 289
  • Thread starter Thread starter enferno
  • Start date Start date Jul 8, 2006
enferno
418
  • Jul 8, 2006
i have a 66 with a stock 289 & c4 tranny. while it's at the paint shop, i plan on rebuilding the engine.
it's a well-used 289, almost 180k miles on it, but it still runs decent.
in terms of overhauling it, what is your opinion on what i should replace?
valves, pushrods, rockerarms, springs etc>
D
D.Hearne
11,730
south louisiana
Jul 8, 2006
  • Jul 8, 2006
You need to tear it down to get an accurate picture of what it'll need. A basic rebuild only re-uses the crank, block, rods, heads, & valves. Everthing else is changed for new parts. Rings, pistons, bearings, timing set, cam, lifters, pushrods,springs,oilpump, oil pump drive,gaskets. Plus a few other parts that don't come to mind.
rbohm
6,698
550
204
tucson,az
Jul 8, 2006
  • Jul 8, 2006
what you need to replace depends on what you are building the engine to do. if this is a basically stock rebuild, then only replace the parts that cannot be rebuilt or refreshed, things like bent valves, etc. i would replace valve springs though as they tend to lose spring pressure over the years. rocker arms are a wear item, and should be replaced. this would be a good time to upgrade to roller rockers. pushrods should also be replaced, along with lifters and cam. main and rod bearings need replacement, as do rings and gaskets. cam bearing need close inspection, and can often be left in place as they dont get the kind of wear other bearings get, BUT definately have them checked. pistons will need replacing. connecting rods can be rebuilt with no problem, as long as they are in one piece and are not too badly bent. the crank can be freshened up, again as long as it isnt cracked, or otherwise badly damaged.
i do recommend a few upgrade though, things like screw in studs to replace the stock press in studs in the heads. roller rocker arms. definately have the rotating assembly balanced. check your stock balancer, you may have to rebuild or replace it. you can get new ones for the price of having yours rebuilt.
Max Power
1,774
St Paul
Jul 8, 2006
  • Jul 8, 2006
First I would do if I were you is buy this book:
http://www.amazon.com/gp/product/19...102-5875012-8140153?s=books&v=glance&n=283155
68RustBucket
119
Linwood, NJ
Jul 9, 2006
  • Jul 9, 2006
1) Buy that book
2) tear the motor down to the bare block
3) take the block & crank to get checked out. clean and check the block for cracks, possibly bore if needed. clean and check the crank for straightness, get it cut if needed.
4) inspect and clean up the other big parts (heads, intake, pistons, rods) for possible reuse, depending on how you want to build the motor.
**READ UP ON SMALL BLOCK FORDS AS MUCH AS YOU CAN BEFORE / WHILE YOU WORK ON THE MOTOR
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
F
289 to 302 Engine
  • Fri Guy
  • Feb 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 13, 2025
Fri Guy
F
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
