rebuilding motor: ring problem
  • Thread starter Thread starter blue87lx
  • Start date Start date Oct 19, 2005
blue87lx
175
  • Oct 19, 2005
im putting new rings on my motor and they all fit except the oil rings. i replaced one piston and the rings fit fine but on the original piston the oil rings wont fit in the groove enough to get the piston in the cylinder. whats wrong. i double checked and the rigs are correct for the motor. and nothing is bored or oversized.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 19, 2005
  • Oct 19, 2005
I would replace all the pistons IMO.........
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Oct 19, 2005
  • Oct 19, 2005
i ran into the same problem. i got three different sets from summit and they were all wrong. so i just got new pistons and rings from my machine shop
vristang
4,933
101
124
Seattle
Oct 19, 2005
  • Oct 19, 2005
I am not trying to be a smartass, but are you using a ring compressor?
Other than that...
It sounds like the outer diameter of the ring is too large.
Is the ring end gap good?
jason
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Oct 19, 2005
  • Oct 19, 2005
from what in understand, the ring is too wide to fit into the groove. thats what happened with mine anyways
blue87lx
175
  • Oct 20, 2005
thats what it looks like. like the inside diameter of the ring is to small but it worked on the new piston
W
Wicked_306
45
  • Oct 20, 2005
Mine were like that too with new Keith blak pisotns and sealed power rings. I just had a friend squeeze the compressor really tight to get them in there, while i taped them in. They are suppose to fit reallly snug.
BlackBaer5.0
100
  • Oct 24, 2005
I did a block assembly last week and if it wasnt for a little advise from the machine shop I would have ran into the same problem.
there are several rings sizes/part numbers that show up for 87-91 50 HO blocks,
For the forged pistons the ring width is metric and the Hyerpueretic (sp?) piston they are standard sizes..
I think the forged piston rings are 1.5 mm // 1.5mm and 2mm I was pretty tired when i put it together friday
I used a sealed Power/ federal mogual ring set,
I hope this helps ..
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
