Recomended Plug and Gap size when Using NOS on a 1987 Mustang?
The UR5 shows all the proper measurements & is one heat range colder than their stock replacement UR45 plug. On a 100 shot 1 step colder at .35" gap with 4 degrees of timing retard should be okay on a minimum of 93 octane. If you plan on spraying more than 100 & are set on NGK plugs, go with the UR6.
