Hello all, about 2 months ago I bought an 88 GT fox and have gone through and been slowly putting money into her running into the usual problems I hear about and have had little issue with the car so far. Today I was driving the car down a stretch of road I always enjoy and punched it in 2nd till around 5k rpm I then clutched in and went to shift but the car I then noticed was still accelerating and bounced off the limiter for a sec and then stopped suddenly. I put the car into 3rd and figured I had just accidentally touched the gas pedal. Later on a similar accident happened when I was half throttle approached a turn clutched to downshift and again it decided to bounce off the redline for a 1-2 secs and then went to normal idle, this time I was sure I didn't touch. The gas and a little smoke came from the air vents
I let the engine cool and turned around to go home with no more issue. Gas pedal didn't stick in gear so I don't see how it could be the cable thought I would ask for some advice as I am not the most mechanically knowledgeable and this is the car I am learning on. Any advice would be appreciated. Thanks
