Reinstalling Vibration Damper....
  • Thread starter Thread starter Grandmaster
  • Start date Start date Dec 31, 2004
Grandmaster
374
Monticello, Arkansas
Dec 31, 2004
  • Dec 31, 2004
Hello,
When I removed my vibration damper to get my timing cover off i marked the damper and pulley because my Haynes manual said they're balanced as one piece. So i have those marked so that i can line them up properly together when i reinstal them. However, i was wondering, does it not matter how it is lined up with the crank? If i put it on upside down from how it was does it not make any difference? I got a feeling this is a dumb question but i dont know much about these parts and it seems if its wrong it could be a really serious screw up. Better safe than sorry... A bonus question: When i put my thermostat back in, should the pointed side face the intake or the radiator? Hope that question is clear. Thanks a lot,
-E
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Dec 31, 2004
  • Dec 31, 2004
you wont be able to put the harmonic balancer on in any other way than the way it came off. its got a key way on it that lines up with a groove on the crankshaft. as far as the tstat goes, put the end with the spring in the intake....so i guess the pointed side would face the radiator. good luck
Grandmaster
374
Dec 31, 2004
  • Dec 31, 2004
Oh ok i see. Thanks!
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
