rejetting holley
351w fastback
91
my car cuts out at about 5,200 rpm like it just quits for a second then picks up again. would this be because of my jets in my carb are too small?
here is my setup:
351w 9.5:1 compression
trick flow twisted wedge heads
comp cams 274h cam
holley 750
weiand stealth intake
c-4 with a 2500 converter
8.8 rearend with 3.73s
the jets in teh carb right now are 72 and 75.
thanks for any help
Its a possiblity. They seem kinda close together. there is a possiblity of something else being the problem. But since you asked for carb advice I would increase the secondaries to about a 77 and see if it changes. I was kinda having a 2 fold problem that ended up being something else. The car was getting hot and preignitioning (but silently). I went with a higher octane and fixed my cooling problems (had a partially sticking thermostate) and it went away. The best way to describe what I was dealing with was at about 4800rpms at full power it would almost fall on its face. Felt like it was missing..but not consistantly on one cylinder like a wire or something was failing. Just kinda lost power. I figured out that that was the place on the track that the heat buildup was enough to make it ping. But like I said, it never made a single noise.
I agree that it could be the fuel bowl level and maybe the jets. I would also check the fuel pump and or filter. I have GT40X heads with an E303 cam and a 750 Speed Demon carb. My jets are 75/82. I have never tested air/fuel ratio but that seems to be the combo it likes for the 1/4 mile.
