Your going to throw away the grommet that came out of the new clutch cable location. The grommet that is in the new speedo cable location you're going to use. You'll cut a hole in that grommet but your gonna work your butt off to stretch that grommet over the big end of the speedo cable. Or you can remove whole cable so you can slip the grommet over the smaller end that hooks to the transmission. I personally just worked my butt of and used some silicone spray because I drove the car a while still with the AOD after I installed the new pedals
