Remanufacturing cylinder heads
  • Thread starter Thread starter B-Woo
  • Start date Start date Feb 25, 2010
B-Woo
  • Feb 25, 2010
i have a 1986 gt with a 5.0 converted to mass air, cammed, cobra intake, 60 over bore, 73mm maf, 70mm tb, cold air. engine's comming out for a rebuild and going into a newer shell (this one a lil beat up), i thought this would be a good time to upgrade. i don't want to spend a grand on new cylinder heads so i was wondering if there is a place to remanufacture the stock heads to gt-40 spec. also how much of a hp gain do you get from the explorer heads?
thank you
Bullitt347
I have been doing it wrong this whole time
3,971
2,943
194
Middle of Maine
Feb 25, 2010
  • Feb 25, 2010
By the time the stock heads are "remachined to GT-40 spec's" you will have spent as much if not more than buying a set of new heads that will outperform the rebuilt stock heads. When it comes to machine work, you usually get what you pay for. To get to GT-40 spec, you are talking all new valves, which may or may not mean new valve seats, maybe new valve guides, intake and exhaust port work, possible re-surface of the cylinder head. For the $ spent, it would be better to save a little bit more and get new heads, unless you want to stimulate the economy of the local machine shop.
B-Woo
  • Feb 25, 2010
well for my application what would you say i do?
Bullitt347
3,971
2,943
194
Middle of Maine
Feb 25, 2010
  • Feb 25, 2010
If the price is right, go with the Explorer heads, they are the better option compared to rebuilding stock 5.0 heads, assuming that the Explorer heads are in good condition.
rd
3,316
63
109
Ocean Springs MS
Feb 25, 2010
  • Feb 25, 2010
There is not really a cheap way around heads. I have done this comparison a couple times.. By the time you get new larger valves, new guides, new springs, retainers, locks, and machine work for the new larger seats, valveguide installation , etc, you will be $5-700 or more into them.
Probably the best compromise is to find some used iron Gt40s where you can just have a shop redo the valves, and reuse the springs, etc.
Mustang5L5
Mod Dude
Feb 18, 2001
43,252
17,937
224
Massachusetts
Feb 25, 2010
  • Feb 25, 2010
Since you have an '86, do you have the stock flat-top pistons? Or did you have valve reliefs flycut into them?
If you have the flat-tops, it will limit your choices here
B-Woo
  • Feb 26, 2010
sorry, i really don't know, the block is not the orginal i think it's out of a 93, its really a chopped up car, i think they may be because of the over bored don't you have to install larger pistons?
For Sale Ford 331 stroker engine for sale - with options!
  • TTSaleen
  • Jul 1, 2026
  • Engine and Power Adder
Engine and Power Adder Jul 2, 2026
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Friday at 12:37 PM
fasterthangas
F
Fuel 19lbs EV6 fuel injectors, what fuel pressure???
  • PonyGTrider
  • Jul 11, 2024
  • 6 7 8
11K
Fox 5.0 Mustang Tech Jul 25, 2024
PonyGTrider
