IMO, it's far more likely that the #8 COP is burning up because of excessive dwell. Causes include a wiring fault (grounded signal return) or bad PCM coil driver.
Recommend that you do not ignore this as there is a real risk of engine fire.
I have helped ppl before with similar problems. One ignored the recommendation to fix it ASAP and an engine fire was the result. Destroyed the wiring and fuel rails in additon to all PVC and vacuum hoses. Very $$ repair.
Since you haven't included ANY information about your remote start (model, how it's wired) it's not possible to give a real answer. But if asked to guess, cutting the wires is not the way to go. The remote start has to have control of the ignition circuits. Likely cutting the wires will kill the power through the ignition.
