Remove A.C.??
You can't really bypass it. The belt routing won't work. You need to delete it with the Ford Racing A/C delete kit which relocates the power steering pump up higher.
Does your A/C work?? If so keep it.
The pulley robs maybe 1/8HP when it's not on. It freewheels so it's basically an idler.
You save 20-25 pounds of weight.
Like i said, if it works, keep it. If it doesn't work, then go for it if you never plan on fixing it
i dont think you can bypass your ac with just a smaller belt. you can run a smaller belt to get rid of your smog pump though....
the ac has a clutch, so your not losing any hp when its not on, and removing it wont free any hp
