to remove the motor its just the tranny bolts to the motor and the motor mounts rigth ? also can the headers go on before the new motor goes in the car
i totally gutted the engine bay of wiring harness,hoses ,ac compressor, ac hoses
i also removed coolant filler,power steering filler and compressor,
complete removed the intake,fuel rails
i think the only thing i need off the old motor is that metal gasket that goes between the engine and flywheel and a little plug off the heads on the driver side
i think i got enuff room to pull the motor forward then up to remove it i was told i need to remove the radiator
yea like the rust cars been sitting for a year
here is the new motor this picture is a little old i replaced the stock cam gears with adj. cam gears and the timing cover and valve cover is on but its still in the kitchen
