I have a perfect 68 J code fastback that has factory a/c. The body on this thing is just immaculate.
I want to restomod the thing, and really want to remove the shock towers and go to a different suspension, but I don't know if I'm going to be able to bring myself to do it since the car is just so perfect. The main reason for removing the shocktowers is that I want to clean up the engine bay, and have more room for installing the turbo plumbing since I want to keep the a/c and p/s. Also going to something like a MII setup would save a lot of money over buying the TCP coilvoer and r&p steering. The thing already has a tremec and a built 306 with a 9" waiting to go in. I was hoping to make power in the 600-800rwhp (with a aftermarket block). Would there be any problem with twisting up the body using that much power? Also will going with a mII suspension on the front make the chassi less rigid since the shocktowers will be removed?
edit: Just realized I'm a founding member now!!!
