I want to remove my 8.8 before winter sets in. I want to change the gears (3.73 to 3.55), replace the stainless brake lines with new lines to replace the bent and rusty lines from my 5-lug conversion and overall clean it up. I also want to install ABS exciter rings on my Sn95 axles.
What should I do about the brake line from the body? Is there a way i can block it up? I don't want all my brake fluid to flow out. Can i put a bolt and nut with two copper washers in it and tighten it up?
What do you guys do to plug that line up?
Also what's the safest procedure for removing the axle? What would you remove first? I ave the car on jackstands on the body so i need to do this on my back and don't want an axle falling on my face
