Removing AC
  • Thread starter Thread starter Guero
  • Start date Start date Jul 2, 2009
Guero
2,148
Jul 2, 2009
  • Jul 2, 2009
Is there a way to remove the ac compressor and move the power steering pump in its place? I mean like a free way lol except for the belt of coarse. Im buying a dd so I will only use this car when I feel like it. Thanks
Sorry I cant do a search its blocked at work.
nisreo
178
  • Jul 2, 2009
Not free but pretty close
Ford Racing M-8511-A50 - Ford Racing Air Conditioning Eliminator Kits – SummitRacing.com
you will need a shorter belt. I dont remember the size off-hand. Im sure someone will chime in
skunk21
1,203
Taxachusetts
Jul 2, 2009
  • Jul 2, 2009
The kit that nisreo posted is the best kit for doing this and it's pretty cheap or go to the bone yard and get the brackets from a non a/c car. I used it and it's really easy, it moves the p/s to the factory location of the non a/c cars for a factory finish/look. If the car still has the smog pump or a delete pulley in it's place then you can just get a belt for a non a/c car and you are all set, if it doesn't have the smog pump then run string around the pullies and bring it to the local parts store to match it up. you may still have to play with a few sizes around the one they give you to get it right.
mc0311grunt
86
Los Angeles
Jul 2, 2009
  • Jul 2, 2009
unless you are trying to take weight off the front end the ac pulley spins pretty freely. It is just a weight thing. Good luck finding a cheapo kit.
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
