Removing all the air bag sensors and wires.
  • Thread starter Thread starter StreetDreamsGT
  • Start date Start date May 10, 2009
StreetDreamsGT
449
New Jersey
May 10, 2009
  • May 10, 2009
I recently swapped an 89 tilt column in and I want to remove all the air bag wires and sensors. I've heard there are two blue chimes under the dash and another 1 or two crash sensors in the front? I also want to remove the cruise control stuff so if anyone can tell me where everything is i'd appreciate it....pictures would be nice too, if anyone has em.
Turd Tops
103
South Lyon , Michigan
May 10, 2009
  • May 10, 2009
I might be wrong but i belive if you remove the VSS from the cruise control you will have problems with the driveability. Maybe someone else can chime in on that.
StreetDreamsGT
449
New Jersey
May 10, 2009
  • May 10, 2009
The VSS is the sensor that plugs into the trans though isn't it? I'm only talking about the sensor or whatever it is that I heard is in the fender...
J
Jack's95gt
443
Huntingdon Valley, PA
May 10, 2009
  • May 10, 2009
You should have 3 crash sensors mounted between the top of the radiator support and the front grill. The air bag control blue box is behind the radio and a/c controls. Remove the air bag dash light bulbs also or it will continue to flash.
Your cruise control servo is in you driver's side fender well, control box in or around the driver's side kick panel. There's a brake petal sensor that you won't need. Your looking about 20 lbs of weight saving.
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
D
75 mustang column/ignition switch wiring diagram
  • DFlikks
  • Aug 7, 2025
1974 - 1978 Mustang II Talk & Tech Aug 7, 2025
DFlikks
D
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
