Removing and installing injectors
Ted87GT
58
Southern Maine
Still working on installing the Trick Flow Intake. Finally got the old manifold off. Thanks to all who helped with that! Now I can't figure out how to remove the injectors? The instructions are no help. The factory manual doesn't help. I did a search of the forum but didn't find anything. Again I am worried about breaking anything. What's the story?
Dude, I just sprayed them with a little penetrating oil and used a claw hammer and a screwdriver for leverage to pry them out. It sounds dirty, but it works the best. It's not manditory, but I usually replace the O-rings and give the new ones a light coating of oil before installing them. They'll slide in slick as snot.:nice:
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
