First you need to get the handles off, the window crank is held on with one screw, but you need to get the little silver cover out of the way first. It's just held on with a bit of adhesive, so a thin screwdriver or the tip of a utility knife will work. Once you get the handles and armrest (two phillips screws) use either a thin, wide screwdriver, or a stiff putty knife to gently pry the clips out of the door. The clips can pull through the fiberboard door panel if you're too rough, so take your time and work your way around, gently prying each of them loose (there's a ton of them) until you get the panel off. There should be a paper water barrier on behind the panel, it's held on with some truly sticky goop that doesn't dry, so you can re-stick the water barrier to it when your done. Hope this helps, the window parts can be a challenge, but just take your time.
