  • SN95 4.6L Mustang Tech
Removing flanges on driver side header
  • Thread starter Thread starter BlkDragon
  • Start date Start date Feb 18, 2004
BlkDragon
162
St. Louis
Feb 18, 2004
  • Feb 18, 2004
After taking off the mid pipe, how did you guys get these suckers out. I've been trying vice-grips but those suckers are in there good. Any other tricks?
03Sleeper
464
Fordville,USA
Feb 18, 2004
  • Feb 18, 2004
I'm not sure what your talking about But Try some WD40 and a Impact wrence if your talking about the studs holding the Mid pipe to the headers?
BlkDragon
162
St. Louis
Feb 18, 2004
  • Feb 18, 2004
It's the bolts that come out at you on the drivers side. Im trying to replace those w/ the ones that came w/ the kit to prevent a drivers side leak
03Sleeper
464
Fordville,USA
Feb 18, 2004
  • Feb 18, 2004
I think I know what your talking about but You aren't being super clear?
Just WD40 the Hell out of the bolts andyou should be fine!
Assuming we are talking about the same thing as It's hard to know what the situation is!
UA2k1GT
Boned
2,634
Bham/HSV, AL
Feb 18, 2004
  • Feb 18, 2004
replacing the studs on the driver's side manifold. Get some PB Blaster and spray the crap out of them, preferably let it soak over night. Then spray again.
Take one nut and thread it on there, take another nut and thread it on the same stud. Make the nuts touch each other, then put the wrench on the first nut you put on and remove the stud. Do the exact opposite to put the new stud on
BlkDragon
162
St. Louis
Feb 18, 2004
  • Feb 18, 2004
Thanks for the help. I used the 2 nut trick and finished the install. Everything sounds great and I haven't heard any leaks.
Sorry if I wasn't clear before, b/t sitting at the computer, lying under the car, and driving over to Home Depot I was really rushed to get the pipe installed before the sun went down.
03Sleeper
464
Fordville,USA
Feb 18, 2004
  • Feb 18, 2004
No problem I've been down that road ..Running out of daylight and getting cold laying on the floor of the garage aint Fun!
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
