When dropping the fuel tank, do you leave the fuel filler neck attatched to the tank, or do you leave it attached to the car? If I'm pulling the filler neck and tank in one picece do I need to remove the screws around the filler neck gasket where it meets the quarter panel?
When reinstalling the lock ring for the fuel pump assembly, is there a gasket underneath there that needs to be replaced, or does it need silicone or anything like that?
Anything else that I need to know before I put a new fuel pump in?
