  • 1994 - 1995 Specific Tech
Removing stripped bleeder screw?
  • Thread starter Thread starter sage2k
  • Start date Start date May 30, 2006
sage2k
645
Baton Rouge, LA
May 30, 2006
  • May 30, 2006
I went to go bleed brakes and one of my bleeder nuts is rounded off, how do i remove it and install a new bleeder?
FORCED2DV8
458
Grand Rapids MI
May 30, 2006
  • May 30, 2006
Try Chanel Locks, or Vice Grips, Or tap a easy out in the hole and work it out that way, spray some wd-40 or similiar on it.
95strokerPSU
986
Sacramento from Philly
May 30, 2006
  • May 30, 2006
What size wrench is the bleeder? Mine was stripped really bad so I just took the next size smaller wrench and hammered it on. Broke loose like that and then I went and got new bleeder screws.
HISSIN50
34
129
May 30, 2006
  • May 30, 2006
If you have clearnance, a Bolt-out might work for ya.
I used to remove them with vice-grips too.
The combination of galvanic corrosion, pot metal head on the bleeder and hygroscopy in the system can really seize the bleeders in there.
Good luck.
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
