  • SN95 4.6L Mustang Tech
removing the grille pony???
  • Thread starter Thread starter DavidCroft
  • Start date Start date Feb 15, 2004
D
DavidCroft
194
Sugar Land TX(Houston Area)
Feb 15, 2004
  • Feb 15, 2004
How do I remove the pony in the grille? I looked at it and it appears to take a torx wrench(allen wrench in the shape of a star) but in the middle there is a pin that prevents the tool from going in. I know a lot of people with Cobras change out the running horse with a snake. I just want to take the pony out cause it looks cleaner without anything there. Its on a 96 GT if that matters.
sasscuba
304
Tulsa Oklahoma
Feb 15, 2004
  • Feb 15, 2004
You need to purchase what is called a safety torx bit. I called around to some of my local tool places and got 5 sizes in one pack for $2.00. Regular torx will not work the safety ones have a hole in the middle to go around the pin.
RookieOne
Chandler, AZ
Feb 15, 2004
  • Feb 15, 2004
Could do that. Or do it the cheap and easy way. I used a dremel and cut a flat slot through it and took it out with a standard Screw Driver. When I put it back in, I used a new torqx head screw.
Up to you.
Just remember if you remove the center pin, you lose the security feature of the screw, and thus someone can steal you horsey......
later
SonicGT
187
Ypsilanti, MI.
Feb 15, 2004
  • Feb 15, 2004
or you could cut the slot in the torx bit itself, then you would'nt mess up the screw.
RookieOne
Chandler, AZ
Feb 15, 2004
  • Feb 15, 2004
AHHHH!!!
Thats thinking!!!!!
Do'H! Should have thought of that first!!!!!
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Header bolt removal tool/combination of tools
  • BigSlappy
  • Aug 29, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2024
BigSlappy
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
