removing top starter bolt. cant get to it
davins130
424
how the hell do you get that 2nd starter bolt off?? i got a ratchet on it through the wheelwell and could turn it a little bit, but it seemed like it was stripping so i stopped untill i could go out and get a 6 point socket, but with a 6 point i doubt there is enough room to even get the head of the socket positioned right....that thing is on tight as hell too, im going to hit it with some pb's and let it soak for a day. How did you guys get that bolt off?
I believe one of those is easier if you access it from the front....I slap on a bunch of extensions, about 2' worth, and get it by snaking in around the K member...lands right on it...
PB will prolly help you out tho...
the key to my toolbox was on a different pair of keys on a car ive been driving since it broke down, and someone had that car all night so i was working with a very limited amount of tools, didnt have any long extensions or swivels at the time. thanks
Yep, that is the best way to get it.....Good luck.
Scott
davins130 said:
well head broke right off, but its ok because the starter isnt threaded and it pulled right off
Oh, ouch man. Maybe it was cross threaded.....:eek:
If you need tips on getting the old bolt out, shoot me a PM. I have removed 2 bolts that were broken off inside my block.
Scott
