  • SN95 4.6L Mustang Tech
replace fuel filter?
  • Thread starter Thread starter steedastang99
  • Start date Start date Apr 27, 2004
steedastang99
67
  • Apr 27, 2004
I feal like an idiot for posting this question, but for the life of me I can't remove my fuel filer. I removed the 2 c type clamps and then attempted to pull the lines off the filter, they would not budge.
It doesn't have rubber hoses like the Haynes manual shows, but metal fittings. Is there something that I'm missing or am I an idiot?
kj99
346
Spartanburg SC
Apr 27, 2004
  • Apr 27, 2004
I think you need the "quick disconnect tool" you can get one from any auto parts store. auto zone, napa,etc.. it'll say quick disconnect for fuel filter.
I think it's the same for 99+ ...pretty sure
it worked for my 98
KaPPaBaLL
1,326
BAYAREA
Apr 27, 2004
  • Apr 27, 2004
go to your local auto store and ask for a fuel filter disconnect tool. Few bucks it's a shape of an "X"
btw..good times. what mods did you have when you ran that 13.8 with 2.0 60ft?
GDawg
1,469
Nevada
Apr 27, 2004
  • Apr 27, 2004
I don't know about the "X" shaped tool but the one(s) I bought are a pack of 6 plastic disks with holes in the middle of them. Each disk is a different size. On my mustang I have had to use three of them for different lines. You slide the disk over the line (there is a slit in the disk so that you can do this), then you slip it under the metal sleeve on the line and the "protrusion" on the disk releases an inside clip allowing the fitting to come off. There are a few variations that basically do the same thing.
jeff1414
447
Sacramento
Apr 27, 2004
  • Apr 27, 2004
Yeh get those tools!! Even then I had to pull and twist on the left side but it came off!!!
AdRock
521
South Texas
Apr 27, 2004
  • Apr 27, 2004
GDawg said:
the one(s) I bought are a pack of 6 plastic disks with holes in the middle of them. Each disk is a different size. QUOTE]
Those are the easiest to work with. The fuel filter uses the smallest one. They are about $7 for the set at most auto parts stores.
steedastang99
67
  • Apr 27, 2004
Thanks a lot guys, it was driving me crazy. I'll have to do it this weekend. thanks for the props on the time,I think shes got more in her, as for my driving, thats another story. As far as mods, you name it I've got it. Once again thanks.
XTONKAX
619
UT
Apr 27, 2004
  • Apr 27, 2004
It's called a spring lock tool. FYI.
KaPPaBaLL
1,326
BAYAREA
Apr 27, 2004
  • Apr 27, 2004
X shaped disc shaped. all easy to work with..
GDawg
1,469
Nevada
Apr 27, 2004
#10
  • Apr 27, 2004
  • #10
I wasn't putting down your choice in tool. I had just never heard of or seen that one.
KaPPaBaLL
1,326
BAYAREA
Apr 27, 2004
#11
  • Apr 27, 2004
  • #11
i know
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
